Old Mar 21, 2018 | 08:43 PM
cmac4667's Avatar
cmac4667
Default Re: Vogtland Springs
Originally Posted by paintergman
Bringing an old thread back from the dead.
I installed the same springs along with a set of adjustable control arms on my SRT6 and I'm pretty disappointed in the rear ride height. It looks the same or even higher than the stock spring in the rear. There is a noticeable drop in the front, about 1.5" but the rear looks odd.
Seems like I may have to try the Eibachs as I'm looking for the rear to drop about the same amount as the front. It's either that or get a set of NA springs and cut those. I could go to the thinnest pad in the rear but I don't know if it will get the rear as low as I'd like.
The rear wheels have moved noticeably closer to the front of the wheelwell after the spring install and gets even closer when the center section is jacked up and the rear suspension is hanging.
What was appealing to me about the Vogtland's were a slightly softer ride and a slight rake just didn't realize the rake would be that drastic and the ride is much softer than I expected.
​​​​​​Paintergman,
I definitely feel your frustration.
