Originally Posted by Rob M
no service specifically required at 10k. the fss system will alert you when it is time for service with either 1 or 2 wrench icons. you won't void your manufacturer's warranty if you don't go in for service every three months. what service did you have at 9k? an oil change? read the service schedule in your owner's manual to get familiar with what is supposed to be done at each interval. chances are the technician may not have reset the fss counter when you made your last visit.
below are the steps (summarized from the maintenance manual) that you can use to reset the counter yourself.
1. turn the key to the on/run position.
2. within 1 second press the **** to the left of the display twice.
3. present status for days remaining or distance traveled is displayed. within 10 seconds turn key to off.
4. press and hold **** on left side of display while turning key to on/run again. present status is displayed once more. continue to hold button. after approx. 10 seconds a tone sounds and the display shows 6,000 miles for approx. 10 seconds.
5. release the ****.
So far I've trusted the dealer to do what's supposed to be done. I'll check out the service schedule and make sure. Thanks for the reset procedure!
