Old Mar 24, 2018 | 01:18 PM
midwest911's Avatar
midwest911
Default Re: 05' Crossfire Won't Crank
Please help again. Guys, it been awhile. Drove my 2005 Crossfire to the store today after it had been sitting about 2 months while I was outside the U.S. On the drive to the store heard what sound like water going back and forth in the trunk area. Came out of store try to start car but nothing NO CRANK, NO FIRE. Dash lights, radio etc. all working the spoiler is up and will not go down and I hear some of the relays when I turn the key the run but no crank. Checked the battery and the ground wire appear to be good also found car will not shift out of park to neutral so had to use the multi tool to get the car out of park just to tow home.
I get no code when using a OBD 11 Can Code Reader. I have again solder the 3 contact pins of the RCM and I have made an attempt to pull everything out of the trunk but I am stopped at the 2 soft shaped panels that as it appears will only come out if you break them so at this point I have stopped looking for the lock out pump or anything that could now be wet causing the lock out and NO CRANK, NO START for my Crossfire. Thanks in advance for any and all help.
Midwest911
