Re: 05' Crossfire Won't Crank
I have removed the mats down to the foam panels which have cut outs for the jack on the driver side. I do not see away to remove the foam cut outs when pulled they only come up so far and no more, pulling harder it appears will break the foam panel into parts. Is it another way to remove the form panel in the trunk or get to the system that has locked the car from cranking and starting. Thanks for any help I need it.
