Old Mar 28, 2018 | 04:11 PM
onehundred80
Default Re: Lock/unlock system is not Working
Originally Posted by zalsaigh
The lock/unlock system in my 2004 crossfire is disabled due to a faulty siren which blew fuse #9. After replacing the siren, the system did not come back to function and I do not hear the pump running. I checked the pump and found it dry and unmolested. The remote fab works as usual, the lights flashing normally but the locks would not function. The lock/unlock switch at the counsel is also disabled.
Is there anything needs to be done to bring the system to work?
Looking back on your previous posts I see that at one time you disconnected the pump and BCM (?) in the trunk (fuse?) and I cannot see when it was reconnected. You did say you were going to look for the hissing in the trunk in one of your last posts but you never replied.
You appear to have had an ongoing problem here that has been looked at by you on and off for a year.
You need to reply when you do something as too many people are given the solution and never say thanks or are never heard from again.
