Will this siren "chirp" ?
Mar 31, 2018 | 12:50 AM
33
permalink
Valk
Jul 2007
18,129
1,612
Aurora , ILL
Re: Will this siren "chirp" ?
Quote:
onehundred80
You will need a nut for the stud as the OEM siren uses a T40 Torx tamper proof screw so you’ll need one of those to undo the old one.
It is a M8 nut I believe, I made mine but I forget the pitch, just the regular pitch I guess.
I installed the new Alarm Siren which also chirps with the remote door Lock and Unlock
I needed a gear puller tool to remove the wiper arm from the posts
I also needed a nut to secure this new alarm siren as it has a threaded stud to attach to the existing bracket
The nut that hold the wiper arm is the same one you will need for the siren to attach it to the bracket
I didn't have a Torx bit to remove the Torx security screw that held the OEM siren so I simply turned the siren itself to loosen it from the bracket.
A photo below shows the "Torx Security Screw" in the old siren
Link to purchase >>
Mercedes Alarm Siren - Genuine Mercedes 2198203226
Alarm Siren
Gear puller tool used to remove the wiper arms
09:27 AM
Valk
View Public Profile
Send a private message to Valk
Visit Valk's homepage!
Find all posts by Valk
