Thread: Too quiet
Old Apr 5, 2018 | 10:28 AM
amx1397
Default Re: Too quiet
Before you spend tons of money and then not like the sound, why not try this
remove the rear cats,, remove the resonator. this will not interfere with emissions , but will increase mpg and hp . a muffler shop will most likely NOT remove them so find a small out of the way shop to do it.
most on here say any and almost all aftermarket exhaust has a drone when cruising at any speed. remove the cats Not both on the same day drive it for a day if you don't like the sound remove the res. ,, you have 4 cats the front 2 are set up with 02 sensors, the rear two cats are not secsored so they can be removed search
search::::::resonator delete lots of info there.
