Old Apr 6, 2018 | 01:13 PM
onehundred80
Default Re: Master Cylinder Time?
So it appears Spring is around the corner. I backed the car out of the garage and this year again as last year, and the year before, the brake pedal is not good. I know that bleeding the brakes will make it perfect as before. Once bled, the brakes are fine for the next 9 months I drive it. I am thinking maybe replacing it this year when I get time.
I have read that there is some confusion on the correct part numbers from Cardone and RockAuto. Can anyone confirm exactly what I need for an NA? Or just go to NAPA or Autozone?
Thanks, James
What is the lowest temperature the car sees in the winter months?
When you bleed them do you see air bubbles come out?
