James1549
So it appears Spring is around the corner. I backed the car out of the garage and this year again as last year, and the year before, the brake pedal is not good. I know that bleeding the brakes will make it perfect as before. Once bled, the brakes are fine for the next 9 months I drive it. I am thinking maybe replacing it this year when I get time.
I have read that there is some confusion on the correct part numbers from Cardone and RockAuto. Can anyone confirm exactly what I need for an NA? Or just go to NAPA or Autozone?
Thanks, James
onehundred80
I replaced it with a used part and that was that, it never solved my low pedal which everyone said was normal, so I guess they are correct.
When I installed a set of SS brake lines on my coupe, then flushing & bleeding the entire system, the brake pedal in my Coupe was nice & firm, with only a small amount of travel. But after it sat for awhile, the "soft" brake pedal came back. This was right before the Fall ToD event last year. But the car performed fine up & back & throughout the weekend. I have a new Master Cylinder, but not convinced I need to install it yet. I guess I don't drive the XFire often enough to remember the soft pedal feel as being somewhat normal. That's my story & I'm sticking to it!!!
