Re: Crossfire does not start and does not crank
With the SKREEM , it will try to start 3 times before the engine will not turn over. While at the battery, make sure the cables are clean. Then check the ground cable for corrosion at its grounding point at the fender, also the cable itself. Look at the covering jacket ,make sure corrosion has not made its way up into the cable.
