Old Apr 9, 2018 | 09:31 PM
KDW4Him's Avatar
KDW4Him
Default Re: Crossfire does not start and does not crank
Originally Posted by dylan07
I don't think a bad fuel pump will prevent the car from cranking. I had autozone test my battery he said it was good but the cold cranking amps was only like 560 out of 720 or something like that. I'm going to take the starter out and take it to autozone and have them test it. Unless anybody has anything easier to try first. My dad and I jumped the solenoid on the starter, bypassing relays, security, etc.... it didn't even click.
Taking the starter out now is way too soon in this DX process, and a ton of work. RCM still can be the no crank issue and the most common. Starter not so common. There may be other solder joints bad inside the RCM than just the common 3. I touch up the whole board while it's out. The fuel pump relay can be the rough running part of your symptoms that's why I put those two things together with the RCM and relay contacts.
