Re: Rear subs wiring gone?
That's a good camera angle on your amp photo.
Looking at the two amp wire harnesses from left to right, the left harness has the YL (Yellow), YL/VT (Yellow/Violet stripe) and BL (Blue), BL/BR (Blue/Brown stripe). That is your Left and Right channel wire from the factory radio harness.
Notice also that there are two sets for the Left and Right channels. This is the paralleled wire I was talking about.
Now, on that same harness, you see what appears to be a Green wire. That wire is BL/DG (Blue/Dark Green stripe) remote turn-on for the amp. It's actually a Blue wire with the wide Green stripe facing up. The two Brown wires between the Yellow wire and the Blue/Green stripe wire, are the amps ground wire. No need to be concerned with those.
Those are the wires you will need to connect to the JVC headunit.
You will not have to connect any wire to the second harness on the right.
