Originally Posted by PAULW
Ok the Sprint Boosters arrived late this afternoon so here goes,
I installed mine in less than 15 minutes in this order, pictures
are here: https://www.crossfireforum.org/galle...ry.php?cat=574
1. Remove the lower nut cap.
2. Remove the 10mm nut.
3. Remove the washer, a magnet helps.
4. Remove the pedal, lift the bottom pulling out and pull it out of the upper bracket.
5. Unplug the tps cable from the sensor.
6. Plug the tps cable into the Sprint Booster.
7. Plug the Sprint Booster cable into the tps sensor.
8. Reinstall the pedal assembly.
9. Go for a test drive, you WILL SMILE !!!
This is a short (maybe long) review and for non believers... OK ...
My car will now bark the tires from a standstill and put you back in the seat and I mean instantly, NO HESITATION, RIGHT NOW!!!
Don't believe it ? Try it, you will believe !
Paul, thanks for the excellent instructions w/photos. Can hardly wait!!!
