Old Apr 20, 2018 | 03:15 PM
crazyfred's Avatar
crazyfred
Default Re: Part number and source
Thanks ala-xfire
I'm having an issue when doing a wot push and the gas pedal, the throttle is non responsive until you turn the car off and restart. Th e consensus is that the throttle position sensor is bad. I did see where you had to get the whole pedal assembly. But how can I determine if the pedal assembly is bad or the throttle body sensor is at fault?
The code I'm getting is po123
Tps pedal position sensor a circuit high input.
Thanks for responding and thanks for your help.
Fred
