Re: What did you do to your Crossfire today?
Fault of my own caused this small nipple on my coolant tank to obtain a very small crack
The hose was not all the way over the nipple therefore it had a point it could crack if bent.
For a temporary fix only I cleaned the small crack applied some gorilla glue let it dry overnight slid the hose all the way over the nipple and tightened the clamp right at the point where the crack was.
The car was driveable but still had a slight steam leak.
Fortunately I live close to Rudy (our V8 Crossfire expert and Mercedes Benz mechanic) and he had a spare coolant tank and I was able to pick it up from his house today.
I came home and swapped the tanks and I'm good to go now.
He has tried the Brass Nipple repair on these tanks and has had one that held and one that did not and recommended I simply replace the tank
He explained that when the plastic heats up and is under pressure the brass fitting threaded into the tank even with various thread tapes or sealers simply cant be trusted to hold up under pressure.
I travel to events around the country every year and agreed I wasn't 100% comfortable with this kind of repair even though others here have had success with it
