Re: How to set idle speed, etc.?
There is NO idle speed adjustment, all computer controlled. Normal idle speed is around 640 RPM, you probably have a vacuum leak somewhere.
To remove the cover, grasp both sides at the REAR and pull up, then gently pull up on the front. BE CAREFUL with the front passenger side, it will break.
