DylanHunt
Hello,
I am wondering how you found them in the 5x112 bolt pattern for the Crossfire? I went to several sites the closest they make that wheel in bolt pattern wise is a 5x114.3 pattern. Redrilling the wheels to the 5X112 makes me a bit concerned.
Got them from a distributor and they drilled them, and sent hub spacers.
the tire shop I always use which is awesome, has put 5 sets of aftermarket rims on Crossfires before and they suggested to stud the hubs, they had 3 of the 5 had vibration, they studded the wheels and it was gone, they said they don't know why, but it worked.
mine had some vibration, for the first 100-140 miles then smooth, was planning on ordering some studs the next week, but had a 3.5 hr drive on the interstate the next day after putting them on, and been smooth ever since.
John&Terry
. The technician was impressed with how true they are. Little weight was needed to balance them. One required no weight.
mainly the weights are needed for the tires.
when I bought my I had them put each one on the balancer before mounting the tires.
ANY wheel better be true
