krism
Hey Peeps!
So I bought a Pioneer AVH-3300NEX head unit for my 2005 Crossfire Roadster (with the Infity radio). After some experimentation, I managed to get sound from it. However, if I turn the stereo up past about 14 (out of 40) it starts to distort horribly!! Anyone have any experience and/or ideas as to how to rectify it? I'm about 5 minutes from taking it to CarToys or the like....!!
Thanks,
Kris
Are you using the unit's internal amp, the Crossfire external amp or another non-factory external amp?
If using the internal amp:
- Do you have the rear speaker set up as such or for subwoofer? (This is a menu setting. Make sure it matches your setup. And if you are using a sub, make sure your wiring matches the proper ohm rating. Bad sound and other issues can arise if this is set incorrectly.)
- Are you running through the speaker outs from the unit, or via the RCA jacks? (Use the RCA's if going through any type of external amp.
This isn't an exhaustive list, but it should get you started.
Las
