Re: 2006 crossfire- roof switch blinking rapidly, roof inoperable
Youngautomechanic
I have a 2006 crossfire convertible. The top is stuck in the down position. When I try to operate roof with switch it does nothing. The switch just blinks red rapidly. I have tried to manually operate it and when I raise roof halfway it doesn't want to move. It stays stuck, like the hydraulic pressure will not allow it to go any further. I have SnapOn's Modus, and can get into roof module but there is no codes present. The power locks do not work. And there is a code In the Body Control Module- no comm. With central locking pump. I have checked all fuses. I NEED help, please.
I suspect, a security locking pump failure. In the trunk and likely under water.
I have replaced it on two cars and likely will be doing so on a third this month.
