Old May 2, 2018 | 11:13 PM
alexdc's Avatar
alexdc
Default Re: Pioneer AVH-3300NEX
The infinity amp expects at least 4 v PTP input. If your head unit is one of those 2.5 volt PTP units, then you have to use the speaker ( amplified ) outputs from the head unit.
You will get some distortion, unfortunately.
The preamp output is just what it means - the signal BEFORE the internal radio amplifier.
( PTP means peak to peak BTW )
Bottom line, do your research and ensure the unit you are installing has 4v preamp outputs
Like I said earlier. I bought the exact same head unit as the op. SO I guess I will use the RCA.
