Old May 13, 2018 | 05:58 PM
ala_xfire
Default Re: engine stalls on acceleration
I find it hard to believe just because they are not Bosch things would not run correctly
However, it's true. The thing is that when the Chinese cloned the Bosch CPS, they failed to duplicate the connector pin dimensions. Their pins are thinner, which results in the body harness connector not making proper contact.
Torque Pro - a cell phone app that interfaces via a bluetooth connector to the OBDCII connector.
TPS - Throttle Position Sensor
Advance - regarding the ignition timing.
MAF - Manifold Absolute Pressure sensor.
CPS - Crankshaft Position Sensor
