Old May 17, 2018 | 02:47 PM
musec03's Avatar
musec03
Default Bow Latch Cylinder Locked Up Cannot Open Tonneau
I wrote this to Pizzaguy and thought it wise to make public....
Hello Pizzaguy ... if you see this today (17 May, 2018) ... I’ve followed many of your posts concerning the convertible top of Crossfire
I have a 2005 Crossfire, Bentley engine model ... other data available upon request
The top has displayed every problem listed and then some...
I'm writing to ask about the bow latch .... I’ve learned how to manually raise and lower the top conv top
Along the way, the trunk has had to be opened via access through driver’s side tail light assembly removal
...and the bow latch has refused to open the tonneau cover after it has been adjusted with the 6mm hex
I saw the latch mechanism through an access hole on the tonneau cover ... it did not contribute to solving the problem of it being somehow stuck in such a way as to prevent the release of the tonneau cover
We managed to put the top down ...and now wish to put it back up.
In short ...after turning the hex screw on the bowlatch ...the tonneau cover is not released so that we may put the top back up
Can you suggest anything that might be holding this up?
Thanks in advance for any help
​​​​​​​Roy
