Old May 17, 2018 | 03:30 PM
Padgett's Avatar
Padgett
Default Re: will not run,help please
The proper way to start is with a pressure gauge on the fuel rail. Should have over 30 psi to idle. If the fuel pump relay then a good chance you have a bad RCM (relay control module). Common problem.
