Old May 18, 2018 | 10:23 AM
X-fired's Avatar
X-fired
Default Re: High Idle - Running Crazy
I had this when a piece of rubber from a disintegrating cone filter jammed into the throttle body and held the throttle plate open a little. I think the car gets confused with the signals from the accelerator pedal signal and the TPS signal
So my guess is that the Throttle Position Sensor has failed. You should get the codes read to see if there is a fault set.
Even without the CEL on there can be a problem already diagnosed.
Thanks 180.
I was just looking at buying an Autel DiagLink. Do you think an AutoZone scanner would show those codes without the CEL being on?
A quick search found new throttle bodies for $1,400 but there are plenty of used ones available.
