Mystery hole cover A 112 014 02 33
Has anybody run into this hole cover on their Crossfire? # A 112 014 02 33
I found it on the ground under where the rear half (though toward the front) of my Crossfire was after I had the car up on ramps to look around at taking the rear fascia off.
It's referred to both as a cover and a Auto trans access cover when I googled the part number on it, my car is a stick but that may not be relevant. I went under again about a week later looking around (with a flashlight for dark corners) and could not find any hole that matched the shape.
I'd like to know if it fell out from where it should be (one retention tab was bent) or if it may be an assembly line "gift" that finally got it's freedom from wherever it was stashed.
