zip439
https://www.crossfireforum.org/forum...tml#post524674
It has been a few years since I replaced mine. I do not remember removing a plastic piece from the replacement, but there are two pieces you are dealing with, perhaps that explains the difference in the pictures you are looking at; Not a difficult job. There are instructions in the link.
The assembly appears to consist of four parts according to a Mercedes parts list, but they may come as one part
Forget this I cannot make seem sensible.
NumberCntNameUsageRemarks5
A0015427218
Replaced By:
A0041535328
SENDER UNIT
A0041535328
Replaced By:
A0061532728
OIL LEVEL SENSOR
A0061532728
Replaced By:
A2759050000
SENDER UNIT
OIL LEVEL CONTACTOR
A2759050000
FILL-LEVEL SENSOR
OIL LEVEL CONTACTOR
A0239974348
SEAL RING
17
N910143006001
HEXALOBULAR BOLT
OIL LEVEL CONTACTOR TO OIL PAN
M6X16
29
A0005425118
Replaced By:
A0009050700
SENDER UNIT
COOLING WATER TEMPERATURE
29
A0009050700
TEMPERATURE SENSOR
35
A0229979848
SEAL RING
41
A0089889178
CLIP
TEMPERATURE SENSOR ON TIMING CASE
A0015427218
Replaced By:
A0041535328
SENDER UNIT
A0041535328
Replaced By:
A0061532728
OIL LEVEL SENSOR
A0061532728
Replaced By:
A2759050000
SENDER UNIT
OIL LEVEL CONTACTOR
A2759050000
FILL-LEVEL SENSOR
OIL LEVEL CONTACTOR
A0239974348
SEAL RING
17
N910143006001
HEXALOBULAR BOLT
M6X16
29
A0005425118
Replaced By:
A0009050700
SENDER UNIT
29
A0009050700
TEMPERATURE SENSOR
35
A0229979848
SEAL RING
41
A0089889178
CLIP
