Old Jun 4, 2018 | 11:00 AM
Padgett's Avatar
Padgett
Default Re: Little help please? Battery/Charging system?
I would consider 14.2v to be an upper limit for a good alternator, 14.2-14.8 volts sounds too high, jumping around sounds like a connection issue: regulator, wiring, or even a failing battery terminal. When you crank it to start in the morning, check if any connection gets hot.
