Old Jun 6, 2018 | 06:47 PM
Padgett's Avatar
Padgett
Default Re: Car wont start. please help
How long has it been "cranks but does not start" ? Did it run while you had it ?
What you do next depends on your skill level but anything is fixable.
First thing is to download the '05 service manual (.pdf in Archives) and read up on what to check when it does not start.
That said if mine I would remove the engine cove & introduce about 1/2 oz of hi-test into the intake (do not pour on MAF sensor. Then replace the cover. Crank it and see if it even sputters. NOTE: usual caveats about professionals only apply.
ps if sputters usual culprits are fuse 5 or the fuel pump relay both on the RCM) or a bad solder joint on the RCM. ($128 on Amazon)
