Old Jun 9, 2018 | 04:57 AM
SKW2962's Avatar
SKW2962
Default Re: Bulb Failure Indicator
Thanks guys, but yes when the light comes on I check all the lights, on and off, all work including the licence plate lights and the dash board light stays on until the ignition is turned off. Then may or may not come on next time the ignition is turned on.
As you suggest as it stays on once lit, the culprit should be a brake light, but they work.
