Old Jun 9, 2018 | 08:25 AM
onehundred80
Default Re: Bulb Failure Indicator
Originally Posted by SKW2962
Yes, as per original post, it was the passenger side brake light that was the first problem, but that light is definitely working after the bulb change and when the dashboard light is on.
Sorry, I forgot that.
Are you positive that you have the correct bulb in place, problems have been caused by the incorrect bulb being used. Some bulbs hit two contacts and use two circuits or can be placed 180 out of position due to the bayonet pins fitting a socket that was not meant for that particular bulb.
I am assuming that the turn signal and brake light use the same bulb which has two filaments, I think that is how it works.
