Old Jun 9, 2018 | 10:21 PM
amx1397
Default Re: WTB: 15mm Hubcentric Wheel Spacers
Originally Posted by pholmes237@yahoo.com
I know these are available at Ebay, etc. Looking for a pair of 15mm hubcentric wheel spacers, if possible, with lug bolts. If not that's ok too.
I may have a set at our shop, and lug bolts. I will check Monday,,or Tuesday. Do you have stock bolts now? if yes i could order the ball type lug bolt 15mm longer than stock
if you have aftermarket wheels then the lug bolts would be tapered , you could measure how much the bolt sticks through the rim,, you need 6/8's + the 15mm for the spacer , this would be for the rear, the front can take a longer bolt. The em brake cable is in the way if the bolts are too long. jim
