Old Jun 12, 2018 | 11:10 AM
crossvic's Avatar
crossvic
Default Re: Preventive maintenance on CPS etc
Don't want to confuse everybody.
The part I took out from my 2007 car is 050 (see my previous post), for which, according to the Bosch site, has a Type Formula of PG-3-8. It is discontinued since 04/2014 and replaced by 114.
The always recommended P/N is 037, which has a Type Formula of PG-3-5, which seems less technologically advanced than 114 PG-3-8, according to the slide I found (see my previous posts).
050 should probably be fine.
The difference between PG-3-5 and PG-3-8 is that the PG-3-8 sensor implements the TPO (True Power On) feature, with a higher accuracy.
114 is working fine in my car, same plug.
