amx1397
with 95000 miles i would say , change the oil (use only Mobil one - 0-40 it takes 9 qts,,if the car runs good and you have no codes then change the oil and drive it.
check for oil leak on the valve covers, if yes ,new gaskets ( order from needswings ) trust no one else for the correct parts Needeswings.com good luck. jim
This car is in the UK so postage would be a killer. It is bad enough here in Canada, that is why I buy as little as possible from the US. It is probably cheaper to buy parts over there.
