onehundred80
The recommended replacement sensors are the Schrader 33500 sensor CLICK, these are set by the tire installer or presumably by the seller. They are cloned to your existing sensors and have been proven to work. The aluminum stem is an optional extra, otherwise it comes with a rubber stem.
These work on sensors which use the 315 or 433 MHz bands found on the Crossfire. Schrader has discontinued sensors that worked on only one of the bands, replacing them with the sensor that can work on either band.
So these newer 33500's can be cloned/matched to each original sensor internal code, thus no more need of (obsolete/hard to find DRB3 + cable & software) ? Presumably, any up to date tire shop could do this? This could be the best news since Mobil1 (for those who want their tpms to work).
Thank you 180!
