Re: Green Coolant... What?
antifreeze has different colors, i use prestone and have always had good results with distilled water. Every dealer tries to sell some special brew that is proprietary and expensive. If in doubt, flush and refill, there is a lot of junk in older coolant that needs to be removed. I took the blue goo out of mine when I bought it 2 years old and STRAINED THE OLD FLUID to see the gunk in it. That is an interesting exercise to try when changing the antifreeze if you have not done it before. Woody
