Old Jun 19, 2018 | 07:22 AM
onehundred80
Default Re: Green Coolant... What?
Originally Posted by AlbertFattal
I must have a slow leak somewhere as my coolant reservoir has gotten low triggering the Coolant Dash Light. Went to top it off with Zerex G-05 50/50 and saw that my coolant was GREEN???
Is this good for the car?
How do I test/confirm what type of coolant my car is using to top it off correctly?
Pics below:
The OEM coolant was blue and when I cleared the system quite thoroughly and added the yellow Zerex the coolant in my tank turned to green. It does not take much blue coolant to turn the yellow to green.
If I was you I would take this opportunity and replace the coolant, then you will know what you have is OK.
