You can also determine if this is the issue by turning ignition on, listen till pump stops, turn ignition off, then on again.
Do this about 3 times before you actually go to 'start'
If it fires right up, pressure was the issue.
( and the spec is 52 - 60 PSI - Dave's napping, them old geezers do that this time of day
