Old Jun 23, 2018 | 05:57 PM
onehundred80
Default Re: Exterior door handle
Originally Posted by White Thunder
Yes l can see the cable....so lm thinking that the cable is properly off the handle. ...so now lm thinking do l need to take the inner door panel off.l see a tread where the door handle can be removed without doing that ....so lm assuming that the cable can be taken off and back on with door panel on ....would l be correct ?
The cable is attached to the door lock mechanism and does not come off with the exterior door handle. The cable is attached to the door lock mechanism and the interior lock handle.
