Old Jun 25, 2018 | 08:55 AM
onehundred80
Default Re: Exterior door handle
Originally Posted by White Thunder
So l took the door panel off ..by the looks of it somebody has been there before ....so what l discovered is that there is a gap in between the handle lever and the lock....appone closer look l find a white piece of hard foam ....look like it fell out of something ....l put it in between the gap and tried the handle .......it looks like it fit in there ....tryed opening the door from outside .....it after a couple of try,s works .....so is this factory ?? I need to find a replacement ....
A photo would be the best way to show what you are describing.
