Old Jun 28, 2018 | 08:25 PM
jamesmonter2's Avatar
jamesmonter2
Default Re: Cylinder Misfire Help
I triple checked all the wires. All the wires are brand new. I switched out the new coil with an old coil, same problem. I made sure the boot was seated on the plugs properly as you need to push hard. I disconnected A & B on the pack and re connected to make sure the wire went on the prong. All wires are connected properly. The cars still runs rough. Has no power when you hit the gas, and sounds like it is sucking in air alot when i hit the gas pedal. It takes a few seconds for the car to rev up after i hit the gas, almost like the gas hasnt hit the cylinder yet or too much air? I check the MAF sensor and the elbow under to make sure thats tight, I cant hear any air or vacuum leaks. Any other suggestions?
