Old Jul 1, 2018 | 09:10 PM
onehundred80
Default Re: Installing 'new' side mirror
Originally Posted by BibaResto
There is very little on installing a complete side mirror. I thought I did read that it can be installed from the exterior. If this is the case (I doubt it ) then I'm sure I can figure it out from there.
Assuming I need to remove the interior door panel is the "Door panel removal" started by Muscle fan 21 in 02/10/2010, still the best write up for this?
I have removed one of the door panels but just to get to the speaker. I could have sworn there was a big deal regarding the wire/cable to the door's airbag but didn't see anything about it on this 2010 write-up.
This is the eBay donor mirror. Only two small chips. The one that came with the SRT-6 had been epoxied together and apparently someone bumped it hard enough to completely break if off.
I chose the Ltd. Forum since this is where the most owners are.
You need to read the “Signal mirror instalation” in the Electrical section in my link below.
