Re: swapped diff in less than one hour
So did you have to pull the spring on the right side with the arms detached? Is the drive shafts on the diff bolted to it? I have a diff coming from Quaife to put in my NA coupe. It should be here the first of next week in a diff I sent them. So can this be done over a weekend by one person? The car will be on a lift and I can get help lowering the diff and putting the new one own.
I can handle the exhaust and have changed the drive shaft center bearing last year.
Dan
