Thread: High Beams
Old Jul 12, 2018 | 12:52 AM
onehundred80
Default Re: High Beams
Originally Posted by DHS
So this mourning my high beams would not work, lows and blinkers work but no flash or highs! Looked at the fuse list and it does not show one for the lights! I don’t think both went bad at the same time, anyone seen this?
Thanks
Dan
Is it possible that the main light switch has a loose plug on it or it is at fault somehow.
I think and you could check this but the multifunction switch high beam flash and high beam work through the light switch itself
If t is the MFS then eBay has them used for much less than $450.
