Old Jul 12, 2018 | 03:41 PM
AtomicBubbles's Avatar
AtomicBubbles
Default Re: Drive train "Clunk"
Originally Posted by waldig
May be the preload on the diff pinion - lock parking brake and rotate driveshaft/see if diff is giving lots of play.
Lock in park - secure drive shaft - and then move each wheel on rear to see play is issue.
Call Rob at needswings for info on noise.
Woody
ill try your method Woody hopefully tomorrow when I have time. With the driveshaft held in place and if I turn the wheels should there be any free ply at all? Or should it be lock tight? I suppose doing this will rule out the differential as the culprit.
Ans as to the motor mounts. If you can help me understand why would they cause the problem if bad. Only asking because changing them is a HUGE PITA...
i have replaced the drivers side side motor mount, a common failure when you increase the HP on these things, and I used Woodys method of cable if the engine down to the frame around the motor mount.
But it if need be I’ll replace the passengers side if I must.
Thanks again for the replies guys!
-Darren
