Old Jul 12, 2018 | 05:55 PM
onehundred80
Default Re: Drive train "Clunk"
Originally Posted by waldig
Passenger motor mount is loaded under torque. Driver side is one under stress. Dont consider that is it.<br /><br />There is some WINK in gear sets but should be less than 15 degrees and similar between wheels - tested with parking brake OFF please. Use parking brake to hold axle and see driveshaft motion.... Guess about 1 inch around shaft; motion or play.<br /><br />Did u check fluid for -COLOR??? Honey no silver!!!! Woody
The motor mounts are under compression and tension. Both are stresses but neither are torque.
