Old Jul 18, 2018 | 08:03 AM
tighed1's Avatar
tighed1
Default Re: Xfire Died in Traffic - BAS ESP- no crank
You can open the RCM and force the fuel relay closed (wedge something behind the relay arm so contacts are touching).
Then see if she runs. If so, it's the fuel relay.
When I work on RCMs I always replace the air pump relays (PO410 fault), resolder bad joints (Mystery No Start) AND perform the Me So Horny mod (horn works w/o the key).
IF there is a known problem with no start and the radiator fan spins up REALLY fast with the key in the ON position, I'd replace the engine control relay.
If there's a problem with the wing being stuck in the UP position, BAS/EAS dash faults, speedometer not working, I replace the traction control relay.
In your case (if bad fuel relay) I replace that relay. So it's possible that I replaced your air pump relay and since the fuel relay has failed.
Because of this possibility I offer to replace all relays, minus horn relay (it never goes bad). Gives me (and the owner) piece of mind knowing I'm not sending out a repaired RCM that will fail again in the future. $50 return shipping included.
tighed1@hotmail.com for details
