Old Jul 21, 2018 | 10:23 PM
amx1397
Default Re: Differential Noise
when you pulled the diff and DRIVESHAFT die u check the u-joint and the splines and the center bearing? it took me 4 times under the car to find the u joint was bad ,,,, each time tried to move it ,it was solid once removed i found it. inspect the drive shaft u joint. jim
