Re: Whine whine whine whine whiiiiiine. WHAT THE EVER LOVING CRAP?!
I would say either wheel bearing or tires, is the tire cupping on the insides, uneven wear around the insides ?
if you have a good stable set of jack stands, can put jacket stands under the back, with wheels off the ground, and someone in drivers seat the whole time, turn off traction control and let sires rotate slowly and can narrow down location where you hear the sound.
if it only makes noise when going down the road, and sitting still in neutral, review up can not hear the noise, rules oit the engine bay area, and in drive train.
front jacked up, can inspect the front tires and test play in bearings, trying to wiggle tire, rear has sealed bearings.
send acouple pics of the tire wear ?
1st I would check how the tires are wearing.....
if that is good, can keep narrowing down from there.
