Old Jul 28, 2018 | 08:26 AM
onehundred80
Default Re: AC/Coolant/Radiator Combo HELP
Originally Posted by Fjp3105
Scratch the last post. Got the module switched out. Run the car. Same problem. New fan, not responsive to ac being turned on. Radiator light on from the get go.
Granted the module I just installed is a used from eBay. But I’m lost. Tried and replaced it all. What else could be left?
The heater/AC control on the dash causes problems, one of which is bad contacts between the two pieces that make up the module. See the Index of ...... in my sig and look at the AC section for details of the repair.
Also what about the sensor on the hose below the rad coolant overflow tank, is it plugged in or possibly failed? I may be grabbing at straws on that one.
