Old Jul 29, 2018 | 09:22 AM
onehundred80
Default Re: New here and very lost
My car sits in a garage all the time. I seldom leave it parked anywhere, therefore, I'd disable mine if I could.
But, the issue is that the ECU talks to the SKREEM and if it can't get an "OKy-DOkey" from the SKREEM, it won't let the engine run.
You'd need to get into the code of the ECU and modify it such that it does not expect the SKREEM's permission to run the engine.
And perhaps that is possible, but it is certainly out of my league.
It is easy to disable these cars, pull the RCM fuel pump fuse for example, pull plug from the CPS etc.
Just do not forget you did it and come here and ask for help.
